Dallas Cast Iron Block Welder Recommendation
Old 11-21-2010, 09:45 PM
JAKEJR's Avatar
Default Dallas Cast Iron Block Welder Recommendation
I'm hoping someone can recommend a welding business in the Dallas, TX area that can weld up a small block coolant leak at the bottom of one cylinder.
The shop that did the clearancing for a stroker crank broke through so it's repair time.
Thanks for any help.
Jake
Old 11-23-2010, 09:59 PM
96capricemgr's Avatar
JB weld and a short fill.
Old 11-23-2010, 10:52 PM
noice's Avatar
Damn man, some people just don't know what they are doing with clearancing for the rod bolts. They probably went to wide on the bottom of the cylinders huh? What I have heard of being done if it is a very small hole is brazing. Other than that, epoxy and a short fill.
