Jegs hub question!
Old 11-24-2010, 10:11 AM
camar0corey's Avatar
Default Jegs hub question!
So I got the Jegs hub in today so I can finish up this 24x project!
Question is about the black peg.
I take it I want to remove it? Does it just screw out or what? What is its purpose? I know the ASP pulley is no where near sitting flat with it in there.
Old 11-24-2010, 10:38 AM
jaycenk's Avatar
It's an alignment dowl. When I used it with a TCI damper it fit in a hole on the damper
Old 11-24-2010, 12:46 PM
So is it threaded in there or pressed? No alignment holes in the ASP underdrive damper.
Old 11-24-2010, 03:19 PM
MattSapp95_T/A's Avatar
i believe it just pulls out....
Old 11-24-2010, 04:00 PM
robsquikz28's Avatar
yep it will just pull out
Old 11-24-2010, 06:45 PM
BOLO's Avatar
I believe the stock 97 crankshaft hub(shorter in length) is needed to work with the EFI24x kit. Someone can correct me if I'm wrong.
Old 11-24-2010, 08:16 PM
letsrun97z's Avatar
Correct 96-97
Old 11-24-2010, 09:29 PM
That is why I ordered the hub from Jegs. I ordered the 96-97 hub. Mattsapp95 was right also, Advance Auto had a package of crank keys for only $3.50
Quick Reply: Jegs hub question!
