396 lt4 fueling ?
396 lt4 fueling ?
I'm running a 396lt1 and just wondering at what horsepower level do the stock fuel rails become restrictive? I'm seeing more and more set ups with the 6an fittings on both rails with regulator....
My fuel system is pretty stout as is for now,I have a aeromotive pump,also a sec inline pump with adjustable regulator.I running a dualstage wet setup with 42lb inj..so your saying long as its not forced induction the rails will be fine? Thx
its not the rails themselves, its the tiny 5/16 crossover and return that kill the stock setup. I run -8 into the front of both rails, then -6 into the regulator with a -8 return should be good for 1000 hp on E85. No back to back testing, but I feel you get more consistant fuel pressure feeding the rails individually, especially if you're not running a monster of a fuel pump.
