LT1 engine harness..
Old 12-02-2010, 08:49 PM
flyinZ's Avatar
Default LT1 engine harness..
Im just wanting to confirm this, but are ALL LT1 engine harness's the same? Example, would be..A 94' Pontiac Firebird Formula w/LT1 engine harness, is it the same as a 94' Chevy Camaro Z28 w/LT1 engine?
Basically, I've got a deal on a engine harness from a Formula and was wondering if it would work in my Camaro.
Anybody?
Old 12-02-2010, 08:52 PM
ulakovic22's Avatar
As long as it will work with your transmission you should be good to go.
Old 12-02-2010, 10:10 PM
1badzee's Avatar
They are identical. A4 with A4 and M6 with M6
Old 12-03-2010, 06:00 AM
S10Wildside's Avatar
Just be sure that you stay within the same year. From a schematics view, 93 is unique, 94 is unique, 95 is unique, and 96-97 are the same.
Old 12-03-2010, 12:30 PM
robsquikz28's Avatar
yes they are the same
Old 12-03-2010, 12:34 PM
speedracer2536's Avatar
x2.. Just had this issue was trying to use a 96 harness in my 94..
Old 12-03-2010, 02:02 PM
LS1 SPEED's Avatar
this man is correct
Old 12-03-2010, 02:39 PM
curacaoz28's Avatar
Yes and No.
the 94 firebird and 94 camaro is the same
The 95-97 coil connector is different then the 93-94
as lon as they are both M6 because the A4 connector are different then the M6 connector (i mean for the transmission example: m6 has a skip shift connector A4 does not duhh)
Old 12-03-2010, 08:28 PM
flyinZ's Avatar
Thanks guys!
Old 12-03-2010, 10:19 PM
tricked94camaro's Avatar
Originally Posted by flyinZ
Thanks guys!
b-body harnesses are not the same as fbody. ask me how i know
Quick Reply: LT1 engine harness..
