a/c delete question
Old 12-08-2010, 04:33 PM
LTXBOI's Avatar
Default a/c delete question
97 z28 want to install delete pully but dont know what belt i need.anybody have a clue
Old 12-08-2010, 04:50 PM
RamAir95TA's Avatar
Depends on the pulley you have. The EASIEST thing to do is measure.
Old 12-09-2010, 01:05 AM
ORedRoc4's Avatar
Go to advanced auto and you can get a 1LE AC delete pulley for about $20 or $30. It bolts right in place of the compressor and you can use the original belt.
Old 12-09-2010, 09:49 AM
R3DLT1's Avatar
The stock belt worked fine here.
Old 12-09-2010, 10:01 AM
quik95lt1's Avatar
yep same here when i had the accessory bracket still on i just got an ac delete pully from summit for like $30 IIRC and used the stock belt.....
Old 12-09-2010, 08:50 PM
LTXBOI's Avatar
yeah i have the 1le...thanks guys will install tomorrow...
Old 12-11-2010, 11:11 AM
Low N Slow's Avatar
I used the 1le pulley and had to get a shorter belt. What I found out was GM used 2 different pulleys on the A/C compessor, if you have the smaller pulley on your compressor the belt will be the same length, if your compressor has the bigger pulley you will need a shorter belt. My stock belt was 64.3" and the new belt is 63.5"
Old 12-11-2010, 11:23 AM
WhitePhoenix99's Avatar
anybody have a part#?
Quick Reply: a/c delete question
