93 vats module location
Since shbox since is modeled around 95-97 f-bodys I didn't know if it still applied to my 93. I have the card disabled on my tune. I am about to disable it at the starter relay due to it still giving me problems. So where would the module be located and can I completely remove it as well as the wiring harness for it?
I think you have to just ground out the starter relay.
If you open the glove box, its behind it. Reach your hand behind the glove box and back up into the dash and you will find the box you are looking for. I think the wire I had to ground was yellow and black I think. Its on SHbox.com. Very easy to do, took me a month to figure out a 20 min mod. Your security light will probably be lit up but it works.
