how would this work out?
Old 12-15-2010, 08:49 PM
94vet0919's Avatar
Default how would this work out?
hi I'm new to the forum i have a 94 Corvette auto tranny 309 gears
iv had the car a year now and have done a few things cold air,
msd opti and new water pump tranny flush and new filter new msd wires and new nkg plugs i bought it when it had 158000 on it since it was my first kinda fast car iv beat the snot out of it well itsnow got miles still runs fine so theres a little back story
now iv read a lot of articles on the lt1 motor the trans and so on since ic had the tranny looked at and its all good i was thinking this tax time having tho motor rebuild I'm wanting to add FI to it and i know the stock stuff ain't goof to last and the comp is to high so could o get by with a fresh rebuild to stock but add forged pistons and rods i know the crank ain't that great but don't have a lot of money and that it can handle 500HP good as that's what iv read I'm ok with that.
can i get by dished pistons bigger chambered heads to lower compession and increase flow and a good cam for my app and make the engine reliable or should i have it rebuilt and just keep it n/a with the new internals thanks in advance foe anyhelp and comits good or bad and great site read a lot here and a few other forums
Old 12-15-2010, 09:06 PM
RamAir95TA's Avatar
What's your budget? Keep in mind a supercharged build will cost about 1.5x times as much as an N/A setup, and requires a LOT of maintenance and tuning. For a serious bottom end to support boost, plan on spending at least $2500 at the bare minimum with machinework, and that's reusing the stock crank.
Old 12-15-2010, 10:09 PM
94vet0919's Avatar
right now its looking like 2000 i like the idea of n/a but i also what be able to whip my girlfriends brothers 92 viper imreally bad next summer cause all be says is my cars junk and well i love going faster on the road course in willows
Old 12-15-2010, 10:37 PM
hitmanws6's Avatar
For 2K id do a cam swap, full exhaust, 3600ish stall and 3.73 gears. You could do heads and cam, but you would have almost nothing left over for anything else. The procharger kit alone will be more than your budget, let along forging the bottom end and choosing the heads/valve train.
Old 12-15-2010, 11:40 PM
94vet0919's Avatar
i was thinking of just doing a topend build up bit i want the motor to last a lot longer ibwont be doing the work myself id the other problem I'm thinking for next summer that's why this year i just wanted to have the motor perpetrated for a supercharger next year and go na till then
so with it having 176,000 miles i didn't want to beef up just the topend or maybe i mos understood your messagethanks for the replies guys really helping me get a good plan worked out before i start throwing money at it
Old 12-15-2010, 11:50 PM
94vet0919's Avatar
also id do the work myself as the waterpump and opti remove and install only took me 2 hours to do but also had a place to work on it since i moved i don't anymore i read that a rebuild was going to be around 1200 but im going to buy the rebuild stuff since o have a friend thats the parts manager at a local dealer so i get stuff for 20 above cost
Old 12-16-2010, 12:10 AM
RamAir95TA's Avatar
If you reuse the stock crank and rods and use a forged piston, you can probably rebuild the bottom end for around $2000.
Your dealer friend won't help much considering the major parts you'll be going after are aftermarket.
Old 12-16-2010, 12:12 AM
94vet0919's Avatar
aw got ya thanks for the heads up
Quick Reply: how would this work out?
