AI cam and the GMMG is installed!
Old 12-20-2010, 03:13 PM
n2oblkz's Avatar
Default AI cam and the GMMG is installed!
Here's a short idle clip after getting everything done!
Old 12-20-2010, 03:15 PM
RamAir95TA's Avatar
Privacy settings FTL!
Old 12-20-2010, 03:17 PM
n2oblkz's Avatar
Sorry, I'm new to all this networking crap!
Old 12-20-2010, 03:19 PM
RamAir95TA's Avatar
Try posting it on YouTube...if you have an account. Or even Photobucket.
Old 12-20-2010, 03:20 PM
n2oblkz's Avatar
Now it should be good!
Old 12-20-2010, 03:21 PM
RamAir95TA's Avatar
Sounds good man! I was kinda hoping for some revs toward the end though.
Old 12-20-2010, 03:22 PM
AChotrod's Avatar
Sounds good!
Old 12-20-2010, 03:27 PM
n2oblkz's Avatar
I know RamAir, I was home by myself and the weather has been very bad, so I just backed it out to let it run for a little bit before the next snow. I'm gonna get a good throttle blip sometime.
Old 12-20-2010, 03:54 PM
Torque Fiend's Avatar
You're not going to share the cam specs? It's a cam only car?
Old 12-20-2010, 04:07 PM
n2oblkz's Avatar
Yeah, it's AI's 226/234 565/566 cam on a 110 LSA. Below are the rest of the mods. It made 300 RWHP and 314 TQ with bolt on's and no tune. I'll get it to the dyno sometime and see what it does now.
Black 1996 Z-28, 6spd with Pro 5.0 and Lou's Short Stick and MBA ****, K&N cold air, Holley 58MM TB, Granatelli Mass Air Flow sensor with polished ends. Crane valve springs, Trick Flow hardened push rods w/guide plates, Comp Pro Magnum roller rockers Cloyes double roller timing chain. Hooker ceramic coated long tubes with 3" Hooker Y pipe, GMMG Cat back with Powerstick chambered bullet in intermediate Pipe. MSD 6A, MSD coil, MSD plug wires, NGK TR55 plugs. March underdrive pulleys. Auto meter electric Fuel pressure gauge in pod and Scanmaster. Granatelli 255lph in tank pump. Aeromotive adjustable fuel pressure regulator. 6AN braided fuel lines rerouted from factory location. DMS drop springs, BMR control arms, adj. panhard rod. Spohn weld-on lower control arm relocating brackets. Enkei Win wheels with 275/40/17's in front and 315/35/17's in back. Polished aluminum radiator cover, polished aluminum valve covers, polished aluminum Vortech elbow, chrome alternator, ceramic coated intake with ported runners and TB openings to 58MM, ceramic coated water pump housing with Mezeire Electric water pump, ceramic coated accessories bracket. Mad Z28 tune.
Attached Thumbnails AI cam and the GMMG is installed!-046.jpg   AI cam and the GMMG is installed!-086.jpg   AI cam and the GMMG is installed!-087.jpg
Old 12-20-2010, 04:19 PM
camar0corey's Avatar
Looks and sounds great! Well except that bra....
Old 12-20-2010, 04:37 PM
n2oblkz's Avatar
I know...I know. I had the front bumper painted a while back and I can't stand the bugs!
Old 12-20-2010, 05:23 PM
airfix's Avatar
Badass car! Sounds and looks great.
Old 12-20-2010, 05:31 PM
hitmanws6's Avatar
Looks good, sounds similar to mine
Quick Reply: AI cam and the GMMG is installed!
