can i run longtubes without a tune?
Old 12-29-2010, 06:20 PM
LT1559's Avatar
Default can i run longtubes without a tune?
in the middle of installing longtubes. will my car run like crap if i dont get a tune? I've read that some people have had nightmares without a tune and some people are fine, we'll find out after i'm done. Also... everytime i disconnect the battery my car takes a few minutes of driving around to run/idle normal.. but i think that's due to the k&n cai i have though, correct me if i'm wrong. thanks.
Old 12-29-2010, 06:29 PM
bigj2717's Avatar
It will be fine without a tune
Old 12-29-2010, 07:11 PM
lethal bird's Avatar
Yep it will be just fine. Ive been riding with no tune for about a year now.
Old 12-29-2010, 07:27 PM
C/Performance's Avatar
The main O2 sensors and the wiring will need to be lengthened or extensions purchased.
Old 12-29-2010, 07:35 PM
RamAir95TA's Avatar
You will need to delete the rear o2's, either though a tune or 02 sims.
The OP does not have rear O2s so no simulators or tuning is necessary. Definitely wanted to clarify that so he doesn't go trying to delete the O2s he has now.
Old 12-29-2010, 07:48 PM
Badazz 97 TA's Avatar
i recommend buying actual extensions for the front instead of making your own IMO. you'll be fine without a tune. its not gonna kill anything
Old 12-29-2010, 07:58 PM
Spartan7's Avatar
He may. It's a 95 car, and he lives in CA.
Old 12-29-2010, 09:44 PM
carlos64030's Avatar
You may wanna consider getting the LT4 knock module since it's less suceptible to false knock than the LT1 module. Because the metallic noise from the headers is similiar to that caused by spark ping, it causes the knock module to signal the computer that the engine is pinging, and then the computer retards the spark for no good reason. The LT4 module is less sesitive to false indications.
Old 12-29-2010, 09:47 PM
trilkb's Avatar
I think i read awhile back something about lengthening the stock o2's messed with the signal some how? Beleive it was in the same post that someone said that you can use OEM Corvette O2 sensors as they are long enough?
I could have been dreaming though, was awhile back when i read it.
Old 12-29-2010, 09:58 PM
I think you were dreaming. The only way something can get screwed up is if the wires have a short or something.
Old 12-29-2010, 10:21 PM
RamAir95TA's Avatar
Even so, the dual cat CA-emissions cars were still OBDI, which didn't have rear O2s. Still dual cat, but only pre-cat O2s.
True story. The knock sensor circuit can also be sensitized in the tune.
Pretty sure it's the REAR Corvette LT1 sensors that use the longer harness. Info is pretty sketchy on them though...not sure if the harnesses are long enough to justify not needing an extension.
And manually extending the harness (via crimping, taping, whatever) instead of using extensions (which provide the least amount of resistance) has been known to jack with the O2 voltage. I saw this firsthand with hacked wiring on my brothers 97 LT1. SOME people get away with it, but using the extensions is FAR more reliable.
Old 12-29-2010, 11:00 PM
Yep you want the actual extensions. Ask me how i know haha.
Old 12-29-2010, 11:15 PM
IronOutlaw's Avatar
I ruined 2 sets of o2 sensors trying to extend them. Get the extensions. Lt4 knock module is a good idea. No tune needed.
Old 12-30-2010, 12:46 AM
Soooooo... this thread just prompted me to buy a set of O2 extensions.
http://cgi.ebay.com/ebaymotors/ws/eB...1#ht_856wt_939
I lengthened my O2 wires years ago. I dunno if I'm having any issues with them or not, but my car is currently in the shop waiting to be dyno tuned for the new heads and cam that was just installed. Figured I'd go ahead and eliminate any possibilities of any problems by just purchasing some extensions. This is seriously the first time I've ever heard of possible problems by extending the wires.
Old 12-30-2010, 08:35 AM
wrd1972's Avatar
In case there is any lingering doubt. Get some O2 extensions rather than cutting wires.
Old 12-30-2010, 02:22 PM
LT1559's Avatar
where do you guys buy them from? ebay?
Old 12-30-2010, 02:23 PM
happysem's Avatar
I did this too =(
Apparently I'm stupid and didn't learn like you guys...I just tried again lol.
I don't "think" there's any issues now lol.
Old 12-30-2010, 02:34 PM
quik95lt1's Avatar
it will run ok with out a tune.....chances are its going to go rich at WOT i've seen alot of the LT cars do this......a tune will defintaly improve the results of the headers though performance wise....id reccomend getting one done....
Old 12-30-2010, 06:10 PM
nascarnate326's Avatar
but is it worth the huge cost? or just something thats nice to have.
Old 12-30-2010, 06:59 PM
Mail order tunes aren't that expensive.
Quick Reply: can i run longtubes without a tune?
