Dana 60
What did it come out of? It won't be a direct bolt in unless you buy the Strange S60 dana 60 which has all of the mounts cast into the housing.
By the way I have a Detroit truetrac (like a torsen diff, all gears) a set of 3.73's and a cast aluminum rear cover for sale all for the dana 60 if you're interested email me at aero.coupe@hotmail.com
Now you have to spend hundreds, even thousands, mounting spring perches, narrowing or widening it, custom length axles, custom LCA and PHR mounts, brake brackets, etc.
Gonna take alot of work before it's ready to bolt into an f-body. I went that way with a GM 12 bolt and wish I never spent the money. Buying a housing ready-to-go is definitely the best choice, IMO.
It will be way too wide. It will have mounts for Dodge drum brakes, probably a non-posi, wrong bolt pattern for Chevy wheels, no torque arm mount etc, etc...
You will spend at least $1500 getting it to work.
