95 / 97 Bare Block
95 / 97 Bare Block
Hi,
I have a question I have a 97 camaro LT1 and im looking to pick up a block to start a build. I found a block but it is out of a 95 camaro, are there any differences between the blocks that I should know about? If so, what problems might I run into? I tried a search but didnt really find much so I figured I would ask.
Thanks for your time,
Braden
Braden
Great thank you for the info. I just spoke with the guy he said the block came from a 95 caprice and it spun a rod bearing. What should I expect to pay for a bare block ?
No more than 50.. Your gonna have to get it line bored or honed as well if it spun a main bearing and not a rod so lookout for that.. somepeople will flatout lie about it..
Okay so if I check the bore of the block I will be able to tell if it's a l99 correct? Just double checking cause I'm probably gonna check out the block later this week.
"Splaying" is a term used to describe adding two (or more) bolts to a normally 2-bolt main.
A splayed main looks like this: / | | \ The two outer bolts engage the main webbing at an angle. This supposedly makes the mains stronger.
While a normal 4-bolt main looks like this | | | | with the bolts going straight in.
Like AC mentioned, it will be debated forever as to which one is stronger. One would think the splayed mains would be stronger since they make their way onto some serious HP builds but to my knowledge it's never been proven or dis proven.
Generally, both are significantly stronger than a 2-bolt main.
That's MISTER MODERATOR
Two bolt blocks with stock bolts are good for stock HP and maybe some more. They’re stronger with aftermarket bolts or studs. Four bolt main blocks are stronger. A stock four bolt main block has all four bolts straight into the block. Stronger than that are four bolt blocks with the outer bolts splayed, angled to pull at an angle more from the block sides.
It takes an original two bolt block to make a splayed four bolt block. Original four bolt blocks cannot be machined to accept splayed four bolt main bearing caps.
If you’re gonna make a four bolt block, it’s best to start with a two bolt block and go splayed.
This picture is from: http://www.superchevy.com/technical/...lt1/index.html
and it happens to be a LT1 buildup. They've used 4 bolt splayed mains.
