PCM Question
Old 01-04-2011, 08:55 PM
95greenlt1's Avatar
Default PCM Question
Hey Guys just curious I have an opportunity to pick up a pcm from a 95 caprice, obviously with the 4L60. Is this going to make a difference if I use it in my car which is a 95 camaro z28. I'm looking to do some tuning in the near future, and in case i do anything to my pcm, I am looking to have a spare.
Old 01-05-2011, 08:15 AM
mguidry629's Avatar
That is a good question. I have a complete motor and wiring harness out of a 95 buick roadmaster. The PCM looks the same, the harness just has the sensors in different areas. It seems like the pcms would be interchangable, but who knows. Hopefully somebody does and will chime in and give us an answer.
Old 01-05-2011, 11:23 AM
skittle's Avatar
The PCMS are interchangeable but you will have to add an extra knock sensor to your harness. The b-bodies have 2 knock sensors compared to the 1 on the F-bodies.
Old 01-06-2011, 09:39 AM
95greenlt1's Avatar
Yeah, I'm probably just going to try and find a pcm out of an f-body, this way I eliminate these unwanted variables. haha.
Old 01-06-2011, 10:05 AM
TurboBob's Avatar
as long as the service number on the PCM is the same (ends in 8051) then it will work properly (when flashed with the proper tune/software)
Bob
Quick Reply: PCM Question
