Header bolts
Sure.
Make sure you get the 5/16" headed 12-points! They are MUCH easier to get good solid torque on than a 6-point. You may need a thin-walled or modified box wrench to get them tight, but it is far better (IMO) than a 6-point. The 12-points also give you twice as many angles of attack than a 6-point.
Those ARP's are a little pricey but definitely worth the money. Just make sure you get them TIGHT. I'm missing a couple now, since they backed out on me and came all the way out. Would be nice if I could just get a couple individual replacements and not have to buy a whole set.
x2 on the stage 8, didn't need to heat cycle them and re torque. Great header bolts
http://www.ws6project.com/user_stor/...oducts_id=2347
http://cgi.ebay.com/ebaymotors/Stage...item4cf40c52a3
The 12 point bolts were a PITA on my Dynomax headers, I had to go with a 5/16 6 point bolt and use the open end. Just a warning, depending on what headers you get you may not be able to use 12 point bolts.
