MIG or TIG guide plates
Old 01-22-2011, 01:50 PM
97COss's Avatar
Default MIG or TIG guide plates
I 've got my adjustables set and thought I'd tack them while I'm in there. Any thoughts on best way to do this or does it matter? Any thoughts here?Thanks guys
Old 01-22-2011, 01:54 PM
97COss's Avatar
Oh forgot to mention...They are the ISKY hardened adjustables - Thanks
Old 01-22-2011, 02:01 PM
gregrob's Avatar
Why in the hell would you do that
Old 01-22-2011, 02:59 PM
96lt1m6's Avatar
Set it and forget it........
Old 01-22-2011, 03:42 PM
wrd1972's Avatar
If it were me, I would use a bowtie guide plate as a template and MIG the 2-piece Iskys for peace of mind. There is no reason not to weld them solid. TIG is simply overkill.
Old 01-22-2011, 08:05 PM
96capricemgr's Avatar
The reason to weld them is because he is obviously talking about the two-piece adjustable guideplates.
TIG would be nice because it makes a whole lot less mess.
I never welded mine, just torqued the studs and it was fine. If I had access to a tig though I likely would have used it, just a spot is all you would need.
Old 01-22-2011, 08:40 PM
Bersaglieri's Avatar
This.
-Dustin-
Old 01-22-2011, 10:12 PM
97COss's Avatar
3 of the cylinders had a different spacing on them vs. the GMPP plates. I was going to permanently set those for no good reason. Got nothing better to do...
Old 01-23-2011, 12:27 AM
SoxXpupPeT's Avatar
Lol... if you can get the tig welder where it needs to be then do that. you just need to have it so that they wont move apart from you If in the situation that they loosen up. which i highly doubt will happen
Old 01-23-2011, 10:28 AM
The GMPP plates fit a LOT better than say a standard Comp but in no way would I use them as a template to set the Iskys.
Old 01-23-2011, 10:55 AM
97COss's Avatar
I agree with this...I set up the ISKY's from scratch and then compared that with the old GMPP's just for reference sake - ever so slight stance difference on 2,3, and 4. Not sure if this is typical on the stock castings or not?? Thanks for the feedback guys.
Quick Reply: MIG or TIG guide plates
