Those with Stage 8 locking header bolts and LT's
I am using the D-shaped locks on my Stage 8 locking bolts and I am wondering if the cone shaped locks might work better.
I need to get some replacement locks from Stage 8 so I can get either type. Sometimes the D-shaped locks need a little trimming to work best. Maybe the Cone shaped dont require this.
What locks do you guys use with LT's?
I had used the stage 8s and when I did header gaskets I found that they all loosened up a bit. I kept the stage 8 bolts and used a two piece washer from Totally Stainless. Its two stacked thin washers that create friction between them making them lock together and prevent backing out. They are on page 82 of their internet catalogue and are called "vibration proof lock washers-made in Sweden." They work great. Should give the new owner many trouble free, leak free years...
--Alan
--Alan
The only reason head bolts "loosen" is because of gasket compression which requires retightening of the bolts. Use a good gasket and check the bolts after the first few drives and all is good.
Amazes me what people **** away money on but then where it really counts have to "save".
Nord-Lock washers
--Alan
--Alan
If you can get Nord-Lock washers for your headers, then you won't have to worry about those bolts vibrating loose; now stress relaxation and the heat load annealing / weakening a fastener under tension, now that's another story - those are both still issues which cannot be resolved with Nord-Lock washers; to fix those issues use Grade 8 (or Metric 10.9) fasteners threaded into clean lightly oiled holes.
got the stage 8 "D" lock bolts 12 years ago. I don't install the D ring until after a few heat cycles on the headers and then re-tighten. Then I put the D rung with lock clip on.
As mentioned had to grind a few corners on D ring.
few head/motor swaps still using the same bolts...bolts have never backed out to even put pressure on locking D ring.
FTR I have never had a back out problem.
Agreed! My $7 auto parts store MrGasket header bolts are still nice and tight over a year of daily driving later.
In my case it wasn't about "failing to comprehend and learn" I used the stage 8 bolt system, re-torqued the bolts, and the kooks header gaskets basically disintegrated over time, causing a leak and the subsequent "loosening" of the bolts...When I called Kooks about new gaskets even they didnt recommend their own gaskets and suggested the Fel-pros that I wound up installing. I went with the new totally stainless friction locking washer for piece of mind, and frankly, I just wasn't impressed with the stage 8 locking system.
--Alan
--Alan
Village Troll
One of the largest problems with the stage 8 bolts is that because the bolt head is 7/16" you can barely get a wrench on them to truly torque them to where a header bolt needs to be. Therefore you are depending on a "lock" to keep the bolts in place on a header bolt that isn't tightened where it should be to where the gasket will most likely eventually blow out.
Solving this problem is extremely easy. Either an ARP 5/16" or 3/8" header bolt will give ample room to properly torque the headers where they need to be. Gasket shrinkage and a required torquing? No problem! Because of all the room you have it takes a mere 5 minutes to retorque all the bolts. I challenge anyone with stage 8 junk be able to effectively torque their bolts and set the locks to where they need to be w/in that allotted time.
