opti/throttle body advice
Old 01-23-2011, 07:06 PM
jmasek's Avatar
Default opti/throttle body advice
Ok, doing a le2 emissions set-up on a 94 camaro, block bored, mahle pistons, eagle rods, going w/ the 30lb svo injectors, I would like a little info on porting my own throttle body and also what to do about an opti, I've read about vented/not vented? does any opti fit all years of lt1 motors or do I need a specific one for a 94, also where to get one, factory stuff seems a little high dollar. Also any recomendations on plugs/wire set-up for this?
Old 01-23-2011, 07:24 PM
RamAir95TA's Avatar
Leave the throttle body alone. Unless you've got some precision machining equipment porting the throttle body is not something your basic at-home mechanic can do. There are a few people that port stock throttle bodies.
Your 94 came with an unvented optispark. If you wanted a vented opti, converting requires some specialty parts, like a new timing cover, optispark vacuum harness, optispark electrical harness extension, 95+ timing chain (or SBC equivalent), 95+ cam with the stepped nose, etc. Or you can take a risk with the MSD cap/rotor which includes vents.
The factory stuff is a little more high dollar yes, but it also has a fairly high reliability rating compared to all of the other stuff out there.
For plugs/wires, NGK TR55 (3951) plugs and MSD 8.5mm routed in stock locations have served me very well for the past 2 years.
Old 01-23-2011, 07:34 PM
curacaoz28's Avatar
MSD sells optispark with a vent ready to install, when i did mine i did not have to replace my timing cover. Just look for it on summit MSD-8381
and no not all years are the same 92-94 and 95-97
Old 01-23-2011, 10:16 PM
hitmanws6's Avatar
OEM optis are around $350. For your TB leave it alone or buy a good quality aftermarket 58 or ported stock 52 or 54 off of ebay
Old 01-24-2011, 10:26 AM
BigD383lt1's Avatar
what they said!
Old 01-24-2011, 06:41 PM
jmasek's Avatar
ok thanks for the advice, I"ll prob just hold out on the throttle body for awile and focus some money on other stuff.
Old 01-24-2011, 10:39 PM
BigD383lt1's Avatar
I would open the intake to accept a 58mm while you have it off the car. You don't want to pull that later when you decide your ready!
Old 01-25-2011, 04:50 PM
jmasek's Avatar
yeah the intake is at lloyds with the heads.
Quick Reply: opti/throttle body advice
