Noob Question - Removing PCM
Old 01-24-2011, 03:06 PM
00FlowCamaro's Avatar
Default Noob Question - Removing PCM
I'm sending my PCM to get tuned by pcmforless. Just wondering what there is to it. Just a couple of screws or bolts? I've screwed up to much on this car this winter so far, not about ready for another problem.
Old 01-24-2011, 03:12 PM
fex77k's Avatar
There is two bolts holding it down and then you have to remove the 4 connections out of the bottom once you get it lifted out. I think they are 10mm.
Old 01-24-2011, 03:17 PM
Kall's Avatar
2 10mm bolts on top and then pull up and out. There is not much slack in the wires but enough to pull out. 4 wiring harnesses plug in to bottom each a different color that is also marked on bottom on pcm so you cant get them wrong on reassembly. Remove red clips first, then gently remove 4 wiring plugs and you are done. very easy.
Old 01-24-2011, 03:23 PM
Thanks for the responses!
Old 01-24-2011, 03:28 PM
CamaroRacing12's Avatar
yep what they said. you'll be fine. im an idiot and i could do it lol
Old 01-24-2011, 05:27 PM
fex77k's Avatar
Yea good call on the red clips, try not to drop them they are just little red things. There is 2 a connector IIRC.
Old 02-27-2011, 12:48 PM
mcalus's Avatar
Pictures? Is this the same with the LS1?
Quick Reply: Noob Question - Removing PCM
