Which Cloyes timing set for LT1
Old 01-26-2011, 07:39 PM
BOLO's Avatar
Default Which Cloyes timing set for LT1
Which Cloyes timing set or any aftermarket timing set are guys using when utilizing an electric water pump? Thanks.
Old 01-26-2011, 08:02 PM
Blackbirdws6's Avatar
I'm using the 9-3145 here.
Old 01-26-2011, 08:34 PM
RamAir95TA's Avatar
Cloyes 3145/6.
Old 01-26-2011, 10:02 PM
96TransAmboosted's Avatar
Thats a good chain set.... 3145
Old 01-26-2011, 10:52 PM
97REaper's Avatar
Cloyes 3145 FTW
Old 01-26-2011, 11:13 PM
Colin91Z's Avatar
I've been running the Cloyes Hex-A-just for several years now. Very nice set-up, as it allows you to degree in your cam your cam perfectly. It does require a slight modification to the offset adjustment bushing so it doesn't interfere with the opti, but its quite easy. The part # I've been running is 9-3145A. It runs approx $60 more than the standard 9-3145. If you decide to go this route, pm me and I'll tell you how to mod the bushing.
Old 01-26-2011, 11:35 PM
MattSapp95_T/A's Avatar
I use to run cloyes 9-3145 on my LT1 too....
Old 01-27-2011, 06:39 AM
bowtienut's Avatar
Cloyes 3157 here. Single roller, same as GMLT4 ED, but without the WP drive AND without the slack.
Old 02-26-2011, 07:00 PM
BOLO's Avatar
Any timing cover clearance problem running the Cloyes 3145(double roller)? Or how about the Cloyes 3157(single roller)?
Old 02-26-2011, 08:23 PM
Originally Posted by BOLO
Any timing cover clearance problem running the Cloyes 3145?
I would assume it will require some grinding of the cover. I have a TPIS cover which ready for use with a double roller.
Hopefully others still running a stock cover can chime in.
Old 02-27-2011, 01:02 AM
jester1614's Avatar
any one have any input on a comp cams 2100 double roller? I disassembled my motor today and have a 2100 i can use if it is a decent chain
Quick Reply: Which Cloyes timing set for LT1
