AFR Heads
Old 02-11-2004, 02:25 PM
WARNING! Bad Seller Alert
SSC5R's Avatar
Question AFR Heads
I was thinking in ordering a set of 227 bare AFR heads. I don't have a clue in what they flow. Anybody know what they flow and are they worth the money. Thanks.
Old 02-11-2004, 04:49 PM
Elysian's Avatar
Because of the 3/4" head deck, they are cool for boost applications. I found a site a while back where they were flowing about 300cfm out of the fully ported 195cc version of their heads. Then again, that was what the guy posted up. No chart or anything, just peak numbers. Assuming that isn't BS, I would imagine with the 227cc heads you could flow substantially more. I have a set of the 195cc AFR heads and will be putting them on in a few weeks. I would be happy to let you know what kind of gains I get.
Old 02-11-2004, 04:57 PM
NeedforSpd_Z's Avatar
http://www.airflowresearch.com sites pretty easy to follow, looks like depending on your setup they can flow anywhere from 295-309 cfm thats between about .600 and .700 lift. They look great for a solid roller application IMO.
Old 02-11-2004, 05:26 PM
SSC5R's Avatar
Thanks for the info. and Elysian let me know what kinds of gains you get.
Old 02-11-2004, 05:28 PM
Elysian's Avatar
Will do.
Old 02-15-2004, 03:00 AM
JodyJ's Avatar
Hey Elysian,
I also picked up a pair of used 195cc AFR heads, but when I got them I saw 190LT stamped on them on one of the ends. Is yours the same way?
Thanks,
Jody J.
P.S. Sorry to barge in on the post.
Old 02-15-2004, 09:18 AM
Elysian's Avatar
Originally Posted by JodyJ
Hey Elysian,
Thanks,
Jody J.
My heads are currently at the machine shop getting a full port job. When I get them back, I will let you know. What does stick in memory is that the ends have "AFR" engraved on them along with their little airflow logo. I honestly didn't look them over that carefully.
Old 02-19-2004, 07:54 PM
SSC5R's Avatar
I guess I am going with the AFR 210.
Old 02-19-2004, 11:13 PM
ROBS SS's Avatar
I have a set of ported AFR 227's on my car , They flow 331 240 @.600
they are a nice head for boost motors
Old 02-20-2004, 11:04 AM
RacinLT1's Avatar
fwiw there is a group purchase starting on camaroz28.com for afr heads,they need 4 people and have 1.
i have a set of afr 220's,just waiting to go on an engine,waiting for the flow sheet from a mild port job.
Old 02-20-2004, 06:10 PM
SSC5R's Avatar
Great numbers on those AFR 227's. Whats your dynoing?
Old 02-21-2004, 10:17 AM
ROBS SS's Avatar
just a little over 700rwhp with 15pnds of boost, have just changed a few things on my set-up ,blower,t/b, and camshaft..looking to make well over 800+ at the wheels
Old 02-21-2004, 05:45 PM
SSC5R's Avatar
Those # are f__king sweet! What charger are you using?
Old 02-21-2004, 10:36 PM
ROBS SS's Avatar
was using the Vortech YS have changed to the new YSI
Old 02-21-2004, 10:54 PM
SSC5R's Avatar
Is you're yellow? If it is I seen you at San Antonio in the LS1 LT1 shoot out.
Old 02-23-2004, 10:05 AM
ROBS SS's Avatar
yes the car is yellow, at the shoot-out we were running 15 pounds of boost (still using a 8-ribbed belt)...have changed over to cog set-up now
Old 02-24-2004, 01:20 AM
SSC5R's Avatar
If you could say hello to Mike for me. Tell him Aldo Rodriguez said whats up. If its not to much to ask, could you send me some pics. Thanks agine and ones again that's a ******* sweet car!
Old 02-24-2004, 10:50 PM
ROBS SS's Avatar
hey, will do...I think I met you out there last year....we are in the almost done putting the car back together...Hoping to have it ready for the sbso race, so I can defend my Title again this year , Should be a solid 8-sec car this time arround
Old 02-25-2004, 01:09 PM
SSC5R's Avatar
I'm sure you will take it this year to. Best of luck to you...
Quick Reply: AFR Heads
