help with 94 Z28 camaro
Old 01-29-2011, 01:23 PM
Drak03's Avatar
Default help with 94 Z28 camaro
Ok I'm not sure why but when I'm cruising down the road, as soon as I hit around 25 it drops a gear and won't shift again until I let off the gas, and it jerks really bad. And on the highway goin about 55 it won't shift into 4th gear?????
Really needin some help with this one I'm not sure what is causing it and it is an A4. Stock, just had new engine put in, all new fluids.
Any help would be appreciated
Old 01-29-2011, 02:24 PM
Drak03's Avatar
Anyone, bump
Old 01-29-2011, 03:08 PM
defaultexistence's Avatar
does it have the 700r4/4l60 trans or is it late enough it has the 4l60e trans?
if earlier trans sounds like you nee to adjust the TV cable
http://www.tciauto.com/Products/Inst...ble_adjust.htm
Old 01-29-2011, 03:21 PM
IronOutlaw's Avatar
Test your tps.
Old 01-29-2011, 03:27 PM
Drak03's Avatar
Its a stock 94 Z28 camaro so I'm guessing 4L60
Old 01-29-2011, 03:29 PM
Drak03's Avatar
Would the tps cause it to not have a 4th gear on the highway?? Ugh this **** is frustrating
Old 01-29-2011, 04:52 PM
Drak03's Avatar
I'm gonna test the tps tomorrow and hopefully that will fix it. Any other suggestions? Lol anyone got a trans for sale
Old 01-29-2011, 05:48 PM
IronOutlaw's Avatar
When my tps went bad it shifted into second at 3000 rpms and would only go into overdrive going over 70mph,
Old 01-29-2011, 06:42 PM
Drak03's Avatar
Oh ok ill definately get that checked out?? How much is a good one??
And if it helps I can take a video of what it does when I'm in the car
Old 01-29-2011, 11:46 PM
BigD383lt1's Avatar
has the car ever been tuned?
Old 01-30-2011, 09:34 AM
Drak03's Avatar
No it hasent
Old 01-30-2011, 09:02 PM
IronOutlaw's Avatar
IIRC, I paid around 25 bucks for a new TPS from oreilly's. You can test it with an ohm meter. I think Shbox's website has instructions on how to do so.
Old 01-31-2011, 01:41 AM
boostedlt1's Avatar
does it shift into 4th gear on the street? or is it only on the highway that it wont?
my car would never shift into 4th when i bought it. replaced the 3-4 shift solenoid and it worked fine. month later the tranny went. lol
Quick Reply: help with 94 Z28 camaro
