Is it bad that I can change transmissions faster then I can do an intake gasket swap?
Just did my gasket swap and it was ~2 hours including a 20mins part trip, while I swapped out my trans in 1 hour and 27 minutes by myself and a floor jack.
Comment.
Edit: yes im bored as hell.
Comment.
damn that's pretty quick on the tranny drop! the last time i had mine out i think it was about 2 hours, that was my 5th time i think.
intake gasket took me longer than my tranny as well; granted i was messing around with it, seeing how hard it would be to port
I think it takes me about that long to remove the trans (4L60E). Let's see...
Six bellhousing bolts - LONG extension
Four cross-member bolts
Two cooler lines
Four pinion yoke nuts for the driveshaft
Dipstick
Wire connection
Linkage
Done. Yeah, about a half hour to pull it out probably.
Two cooler lines
Dipstick
Wire connection
Linkage
I didn't think the trans was to bad, granted it took me a long time but hey it was my first time doing it. I dont know how you guys get the top 2 bolts with long extenitons i tired that and couldn't get it to work. I found it easier to just lay on the motor and sitck a wrench down behind the motor and get those 2 bolts. Yes it takes a long time and is hard on the hands but it worked for me. I hated the trans cooler lines too those where kinda of a bizzatch.
