throttle cable?
Old 02-06-2011, 10:09 AM
jasonz28camaro's Avatar
Default throttle cable?
Just go a new BBK 58mm and my throttle cable is a little lose and the cruse is too short. when i push me peddle WOT the TB will not open all the way, just needs a little more. The Cruse is also a bit shorter and will not alow it to shut all the way.
Is there a any way to adjust the cables?
Old 02-07-2011, 03:27 PM
ss.slp.ls1's Avatar
You could pull the slack through the little black plastic clip that holds the cable to the accelerator pedal and add another wire clamp. Same goes for the black plastic clip that's at the end of the CC wire where it snaps onto the TB.
Old 02-07-2011, 08:08 PM
Where can you buy those clips, mine is snapped like a coke can. I have never even seen where the cable connects to the pedal.
Old 02-07-2011, 11:34 PM
jaycenk's Avatar
Do you have ASR on that thing? I can't remember if 96's had it or not
Old 02-08-2011, 08:57 AM
Nope...
Old 02-08-2011, 12:01 PM
flame's Avatar
It should fit without modification. Is your cable bracket on the intake bent? The cruise cable has an adjuster built in the middle of it if needed.
Old 02-08-2011, 12:49 PM
Not bent. The cable could have been loose with my old 52mm, I just never noticed. But with the 58mm the cruise is really tight and made me check the throttle when pushing the pedal.
Quick Reply: throttle cable?
