horible vibration
Old 02-09-2011, 09:32 PM
larson99's Avatar
Default horible vibration
at about 4 thousand rpms it gets a horrible vibration wether im in nutural or in gear(less noticable when in gear). at first i thought the engine was starving for fuel because i thought the injectors were cloged up(car sat for five months only getting started once a week) so i just changed them out today and its still makeing a horrible vibration. also the motor mounts are fine but im starting to think it might have something to do with the clutch cuz i got it replaced about two months ago. what do you guys think
Old 02-09-2011, 10:17 PM
Village Troll
SS RRR's Avatar
Year/make/model/mods/manual or auto?
Old 02-09-2011, 10:23 PM
RedHotG8's Avatar
Since you had the clutch replaced more than likely that's the problem. If not the crankshaft balancer could be going bad, which will also cause vibration.
SS RRR an auto trans doesn't have a clutch, even my wife knows that....
Old 02-09-2011, 10:36 PM
BlackBird87's Avatar
you again, but he is right clutch or balancer is were i would start first
Old 02-09-2011, 10:58 PM
Village Troll
SS RRR's Avatar
Yep. Should have read more carefully. Thanks for pointing that out.
I would suggest not driving it until you find out the source of the vibration. Is the clutch the only thing you've done? Any other mods? I take it this vibration just now started or has it been there since the install of the clutch?
Old 02-10-2011, 07:07 AM
draggin97s10's Avatar
there is no balancer on an LT1 car, its a dampaner. Im putting my money on the flywheel. Did you have it replaced? The crank shafts in these cars are balanced nuetrel in the front and by the flywheel in the back. Some more info would be great!
Old 02-10-2011, 11:11 AM
larson99's Avatar
yah got the fly wheel replaced too. and no there is no other mods done to the car. and the vibration started about about a week after i got the clutch done.
Old 02-10-2011, 11:13 AM
jaycenk's Avatar
What is getting the clutch done? What did you or who ever do to it?
Old 02-10-2011, 11:45 AM
larson99's Avatar
lol i had a shop replace every thing clutch pressure plate flywheel and im starting to suspect the shop because i had them replace the master and slave cylinder while they were working on it and i bled the brakes when i changed the pads and there was more air than fluid in the lines. i geuss thats what happens when you take it to a small shop. but what would be wrong with the flywheel/clutch in particular
Old 02-10-2011, 12:06 PM
old93camaro's Avatar
check the trans mount, they tear if there old and make sure the bolt that hold it in did not back out...
Old 02-10-2011, 05:15 PM
Village Troll
SS RRR's Avatar
There's two ways to go about this, either take it back and tell them about the vibration or tear into it yourself. Either way, it's not a good idea to start the engine anymore until it's fixed. I would suspect the flywheel is loose.
Old 02-10-2011, 06:40 PM
larson99's Avatar
damn ive been driving it for several thousand miles and nothing is getting worse how hard do you think it is to drop the t-56 yourself
Old 02-10-2011, 08:19 PM
RedHotG8's Avatar
If it's only been a couple months take it back, you should have at least a 90 day warranty on the labor, maybe more.
Old 02-10-2011, 10:38 PM
Village Troll
SS RRR's Avatar
Depends on your abilities. It's not really difficult per se if you have the correct means to remove it. If you do a search I'm sure there's a write up somewhere on how to remove the trans.
Old 02-11-2011, 09:18 AM
takes me about 30-45 minutes to get it out. thats on jackstands. takes longer to jack the damn car up
Old 02-12-2011, 05:49 AM
95mysticta's Avatar
My money is on the flywheel, trans mount, and or the driveshaft. I had a brutal vibration when cruising at 70+mph on the why i switched out the stock steel one for an aluminum ls1 driveshaft and now have very little vibration. Best 100 bucks ive spent on the car haha.
Old 02-12-2011, 10:35 AM
larson99's Avatar
would the transmount make any sense if its doing it when im in neutural. and i sure hope it is the trans mount i dont wana have to drop the tranny. sounds like a nightmare
Quick Reply: horible vibration
