Piston Recommendations
Old 02-10-2011, 04:12 PM
gregrob's Avatar
Default Piston Recommendations
I might throw a new set of pistons and rods in while I have the engine out for the heads/cam swap.
What's a good, light, forged, piston.
and ringpack?
Motor will see 200+ of nitrous.
Old 02-10-2011, 05:25 PM
TDavanzo's Avatar
How often will it see the nitrous and how long of a rod are you buying?
Old 02-10-2011, 05:28 PM
gregrob's Avatar
Called Clayton and Cory recommended the CP Bullet series piston.
CP Bullet SBC Piston Set Features
* Set of sbc pistons balanced within 1 gram
* 2618 alloy for strength and durability
* Dual forced pin oilers
* Contact reduction grooves
* Accumulator groove
* Forged side relief
* FEA designed forging
* Tight tolerances
* Same manufacturing process as CP Pistons
* Rigorous quality control
* ISO 9000 certified
The CP weighed 407g.
Im looking at a wiseco piston that looks like it would do the trick:
K413X3
only 347g
• Radiused Valve Pocket.
• Skirt design allows for as little as .004"
clearance with excellent wear properties.
• Anti-detonation Grooves help keep the top
ring groove free of carbon.
• Pressure Groove for enhanced ring seal.
• Features Chrome Moly Pins and Spirolox®.
• ArmorGlide™ Skirt Coating.
• Taking the XLS Series a step further,
the GFX ring package and gas
ports reduce friction for noticeable
increases in power.
• Extra deep valve pockets and a
thicker deck allow for higher horsepower,
bigger cams, and more
radically milled heads.
• Skirt coated for lower friction,
reduced noise, and superior life.
The CP has 1.5 mm 1.5 mm 3.0 mm rings.
Wiseco is 1.2 1.2 3.0
Wiseco has several pistons with even thinner / less friction rings but at 200hp nitrous I'm not so sure that would be the best.
gregrob's Avatar
200+ Everytime to the track or street racing.
6" rod
Old 02-10-2011, 06:44 PM
brokenbird's Avatar
mahle is what i would get
Old 02-10-2011, 06:47 PM
z28rob18's Avatar
diamond total seal rings
Old 02-10-2011, 06:55 PM
gregrob's Avatar
Why.?
Old 02-10-2011, 07:02 PM
robsquikz28's Avatar
Cp and 6" rod fo sho
Old 02-10-2011, 07:08 PM
355z28's Avatar
I run the CP pistons and ring pack. I strongley suggest them that and IF you were to have a failure CP sells them individually. They are made out of 2618 which tends to be a lot less brittle then the 4032 mahle or srp piston, making them more reliable on a large shot.
When I built my motor I talked to both companies, mahle saying they felt uncomfortable with anything more then 150 shot being put to their power pack product, and CP saying
"thats it" when asking them about a 200-250 shot. They are very confident in their product and the quality and consistancy in them were great.
Its nice to have a reasonably priced 2618 piston rather then going to a JE.
I also run the compstar H beams. But with your app. Id suggest scats 6" I beams with 7/16s bolts. They're reasonably light and extremely strong. Also whats in Ed Wrights 9 sec. 383.
Old 02-10-2011, 07:39 PM
jasonisdn's Avatar
check and see if you like them for a .030 bore diamond part number 29011
Old 02-10-2011, 07:47 PM
jasonisdn's Avatar
i dont think they recommend any of their piston for anything over a 200 or close.
Old 02-10-2011, 07:55 PM
z28rob18's Avatar
the machine shop i used told me they were the way to go for the nitrous.
Old 02-10-2011, 08:01 PM
jasonisdn's Avatar
my machinist called them before i ordered my je's and that's what they told him.
Old 02-10-2011, 08:58 PM
brokenbird's Avatar
i sprayed 175 to stock pistons for 5 years so why cant a forged piston take it? Its all in the tune up!
Old 02-10-2011, 09:58 PM
gregrob's Avatar
I've been spraying 175 on the stock pistons as well. But Im thinking about forging it while its out.
I've been looking at what Diamond has as well. So far I like the Wiseco piston the best.
Who knows what a stock piston weighs?
Old 02-10-2011, 10:00 PM
gregrob's Avatar
Diamond rings? What kind of piston did you use?
Old 02-10-2011, 10:46 PM
jasonisdn's Avatar
no sir, those are diamond pistons that i have from my last motor. i had hell fire rings. you can call diamond and get all the specs. they said those pistons would take a 300 without issue. if you want them i live about 3 miles from hpc coatings also
Old 02-10-2011, 10:48 PM
1BadAsZ's Avatar
same thing i was thinking. i had 150 on mine with the stock fuel system leaning it out pretty bad im sure lol
Old 02-10-2011, 11:10 PM
gregrob's Avatar
According to this thread the stock piston weight is 532g.
The wisecos would be uber way lighter than the stock stuff...
Old 02-10-2011, 11:11 PM
gregrob's Avatar
Care to post the SCAT part number?
Quick Reply: Piston Recommendations
