injector o ring kit
injector o ring kit
oreillys sells a kit with 2 orings and 2 other things and i dont know what they are does any one know or will i be fine just replacing the o rings?
http://www.oreillyauto.com/site/c/de...2524&ppt=C0024
the orings look good i just pulled all the injectors off. my car has 165xxx miles and i just rebuilt it so i was just checkin the o rings but they seeem fine
You should be fine then. Im the type of person to always replace O-rings and things of that nature. They might look to be fine. but they are ~15 years old with alot of mileage. either which way be careful when putting the injectors into the intake. The last thing you want to do is rip an o-ring and not know about it until you start up the car. just a PITA
Not to mention they are cheap as hell to replace, Just change them to be on the safe side! I made this mistake once and sprung a leak on 2 injetors. More of a pain then the couple dollars to spend on o-rings
