ProCharger LT1 Parts at Brute Speed
http://shop.brutespeed.com/93-97-F-Body_c183.htm
I have quite a few of the parts that go into a ProCharger LT1 F Body system at the above link. If you need something that you don't see, please let me know. Bob
__________________
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
The blower pulley shims can be added to correctly space the pulley to get belt tracking where it needs to be. In most cases only one or two shims are required to correctly space the blower pulley.
I don't know if the larger air filters will work with the twin intercoolers but this one http://shop.brutespeed.com/KN-RE-092...KN-RE-0920.htm works with the LS1 f body without any problems. I'll bet you can squeeze it up there. Depending on your combination and how much boost you're making, a larger filter can eliminate a restriction and you'll see more boost and less belt slippage. Back at the old shop we picked up two psi on one build just by swapping out to this larger air filter. Bob
__________________
