42lb fuel injectors
Old 02-13-2011, 12:05 PM
killerz97's Avatar
Default 42lb fuel injectors
I am going to be buying some 42lb fuel injectors for my motor. What do you recommend and where is a good place to buy them? Thanks
Old 02-13-2011, 12:42 PM
97pontta's Avatar
If your looking for some used ones I've got a set for sale.
https://ls1tech.com/forums/parts-cla...ock-stuff.html
Old 02-13-2011, 05:10 PM
RamAir95TA's Avatar
I used Lucas/Delphi flow-matched 42# injectors.
Old 02-13-2011, 05:30 PM
gregrob's Avatar
I have some Deatschwerks going in mine.
Whatever they are get them flowed and balanced.
Deatschwerks sends a flow sheet w every set
Old 02-13-2011, 05:38 PM
BOLO's Avatar
Joe, you have the part# for those Lucas 42#'s?
Old 02-13-2011, 10:29 PM
RamAir95TA's Avatar
Unfortunately no. I bought them new off of a forum member 2 years ago, so I don't have the original packaging or anything. Sorry!
Old 02-13-2011, 10:38 PM
hitmanws6's Avatar
The SVO Greentops are usually around $200 shipped in the classifieds. Mine arent too far behind, got mine for $150 with the adapters for the EV1 connection
Old 02-14-2011, 12:03 AM
gregrob's Avatar
I would NEVER put used injectors in my engine without having them flow tested and checked out first.
It cost a dumbass acquaintance of mine TWO engines...
Old 02-14-2011, 03:22 AM
hitmanws6's Avatar
My friend took care of that, he had them on his LT1 for around 12K, theen I got them from him. But yes op look for a flowmatched set
Old 02-14-2011, 01:32 PM
brettmc's Avatar
I've had good results with the 42s I bought from these guys:
http://fuelinjectorconnection.com/sh...ewCat&catId=61
Old 02-14-2011, 02:04 PM
wrd1972's Avatar
These guys are good to work with.
Old 02-14-2011, 03:47 PM
killerz97's Avatar
which ones:
http://fuelinjectorconnection.com/sh...&productId=206
http://fuelinjectorconnection.com/sh...&productId=179
http://fuelinjectorconnection.com/sh...d&productId=10
Old 02-14-2011, 04:34 PM
mguidry629's Avatar
Looks like the Lucas are the only ones flow matched but that's $356 for a set of 8. I'm hoping to be in the market for new injectors soon, so I'll be interested in the next few posts.
Old 02-14-2011, 05:55 PM
killerz97's Avatar
I called and the guy recommended the new bosch green giants. He said its a new design and they are $51.95 so just a little over $400. On the website they have them as an ls1 injector but he said they can change the o-rings to fit the lt1 as well.
Quick Reply: 42lb fuel injectors
