just some shtuff
Old 02-15-2011, 10:41 PM
LigHtEmUp01's Avatar
Default just some shtuff
well first off just wanted to say ebay headers and y suck and i would not ever buy them. and 2nd i was justt curiouse how my car will run with no egr, air system? also is it better to have o2's even when the car is gonna be tuned or could i ditch them and be fine after its tuned??
Old 02-15-2011, 10:46 PM
Gojira94's Avatar
Pony up the $175.00 to get it tuned- no AIR is fine if you leave the pump fuse in, EGR you definitely want tuned out if you delete it, front O2s are a must for correct AFR...
Edit: 95 car won't have rear O2s, my bad. Keep the 2 you have.
Old 02-15-2011, 10:55 PM
RamAir95TA's Avatar
When you buy the eBay long tubes, you should accept the fact that they are going to need some minor modifications to get to work. If you're not capable of making the necessary adjustments then maybe they aren't for you.
The car will run fine without AIR and EGR albeit with increased emissions. Just make sure you have the EGR programmed out and leave the O2s and wiring intact.
Old 02-15-2011, 10:57 PM
i will have the egr tuned out but i need to know is it a must to run o2's? im assming it is considering what there purpose is and like in that other thread what is a heated 02
Old 02-15-2011, 10:58 PM
i dont know what the pump fuse is ?
Old 02-15-2011, 11:07 PM
RamAir95TA's Avatar
You CAN run without the O2s, but for anything that sees any amount of street driving there's absolutely no need for it. Keep them.
The AIR pump fuse is the AIR pump fuse. It's in the fuse box.
Old 02-15-2011, 11:10 PM
ok thanks sir. just wanted to say i appreciate all the help
Old 02-15-2011, 11:20 PM
RamAir95TA's Avatar
Sure thing yo.
