octane rating
Old 02-18-2011, 10:25 PM
BigD383lt1's Avatar
Default octane rating
for other then performance reasons why should we run 93 octane.. I have been told that there were two reasons one being is because our cars run higher compression from the factory! So if I am running a lower compression does that mean I can use the cheaper stuff? I know the other reason is because of timing being advanced of coarse.
Old 02-18-2011, 10:39 PM
gregrob's Avatar
Cuz it sounds cool
Old 02-19-2011, 12:41 PM
RamAir95TA's Avatar
Because the owners manual says so!
Old 02-19-2011, 05:18 PM
Village Troll
SS RRR's Avatar
For a factory stock engine you can run whatever octane you want. The knock sensor will adjust timing as needed. It is best to run the highest octane your local gas station offers for best performance results because of the higher compression and timing.
Actually I believe it says it's preferred. Not required.
Old 02-19-2011, 05:22 PM
LSWHO's Avatar
With all the "low octane" tables in the PCM you'd think it would be ok either way... But does anybody actually understand those tables and when/how they are used?
Old 02-19-2011, 05:32 PM
Village Troll
SS RRR's Avatar
I invite you to explain why it is not ok.
Old 02-19-2011, 05:39 PM
LSWHO's Avatar
I first invite you to reread what I said. As I would not argue that. I came from boosted low timing cars. I know my fair share about timing and KR.
Old 02-19-2011, 05:41 PM
Village Troll
SS RRR's Avatar
I have absolutely no idea what point you are trying to make. Regardless a factory stock LT1 can run lower grade octane fuel no problem.
Old 02-19-2011, 05:53 PM
LSWHO's Avatar
I was saying it's ok to run lower octane on a stock car because of the timing tables in the stock PCM. And that there are also some "low octane" tables in built into the PCM, but I can't seem to find anybody that knows how/when they are accessed.
Old 02-19-2011, 11:27 PM
BigD383lt1's Avatar
ok so no one really answered my question. Is it safe to run lower octane gas in a motor with low compression. When I was running my stock motor with a hypertech tune I wasn't able to because of knock. Now I am running a lower compression motor and someone told me it is safe to run lower octane gas. I am running a lt4 knock sensor so I would think that would make matters worse not better in this circumstance. Does compression play any part in this scenario?
Old 02-19-2011, 11:52 PM
LSWHO's Avatar
We have no way of telling you a safe octane to run. You MUST scan it.
If you were stock with less compression absolutely. But we have zero information on your tune, let alone on your motor.
There is, however, usually quite a bit of timing advance on our tunes, so if this is the case, then it's is entirely POSSIBLE that you could very safely run 87 octane. But again we know nothing of any part of your car minus the fact that it's a 383 that used to have a hypertech... so therefore YOU MUST SCAN YOUR CAR TO FIND OUT ON YOUR OWN.
Old 02-19-2011, 11:53 PM
LSWHO's Avatar
Also, scanning software is free for your car. You can either find somebody locally to borrow their cable, or buy your own for $65 shipped and scan it. Show us your datalog and we'll answer your question.
Old 02-20-2011, 08:53 AM
96TransAmboosted's Avatar
87 and 89 burn faster then higher octane fuel, witch is why then cause valve ping and other simular issues on high compression engines. You can run any fuel you want to run but its not going to burn correctly and is going to cost you power and cause premature wear. Im sure this in more of a ? for your tuner than the form,like LSWHO we have no idea what your PCM is seeing or comanding. its a blind guess at this point. For what reason do you run lower compression on yur lt1 for?
Old 02-20-2011, 09:48 AM
BigD383lt1's Avatar
in the future I plan on going boosted but for now I have to wait. As far as the cable I just got it in the mail and I am still trying to get connected for some reason I am not able to connect with tunerpro rt.
Old 02-20-2011, 10:40 AM
RamAir95TA's Avatar
Or eliminate any chance of any issues and just run the recommended 91+.
Old 02-20-2011, 11:31 AM
96capricemgr's Avatar
The b-bodies run on 87 octane with iron heads and just .4 point less compression. Aluminum heads should be more detonation resistant.
So it is very possible to make an LT1 happy on 87 octane, but as said nobody can tell you about your setup especially when you haven't really told us much about it.
Old 02-20-2011, 12:17 PM
LSWHO's Avatar
Did you install the driver for the cable?
Did you select the correct com port for the cable?
I couldn't get tunerpro to connect without constant glitches.
I downloaded tts datamaster and it worked perfectly.
Old 02-20-2011, 02:56 PM
I also like datamasters better myself,
Old 02-20-2011, 10:22 PM
BigD383lt1's Avatar
yes I selected the right com and installed the drivers for the cable. I emailed the guy at tunerpro and he gave me a couple of suggestions. I just need to get to it but, I just lost my starter in dd so I have to go change that out first.
Old 02-21-2011, 08:03 AM
quik95lt1's Avatar
what IS the compression on the motor you built???
and what temperature do you run the motor at??
Quick Reply: octane rating
