Security light comes on an tha car won't even try to turn over..
Old 02-20-2011, 08:50 AM
MAROBOY_TRAV's Avatar
Exclamation Security light comes on an tha car won't even try to turn over..
I KNO I've seen a few threads around for this same situation an I've been hearing it's THA chip inside of my key.. is there anyway around this security set back? Besides having to go and get a key remade?
Old 02-20-2011, 09:03 AM
96TransAmboosted's Avatar
you or a lock smith can ohm the key, get a resistor that same value and slice it into the system. This will enable you to run a non chip key in your car and will do away with this issue in the future.
Old 02-20-2011, 09:17 AM
nascarnate326's Avatar
50 htz box into the pcm(its a blue wire) and ground out the ignition relay(its up under the dash behind the glove compartment.
shbox has a write up on bypassing the VATS system.
the resistor trick is a waste of time. Do it once, do it right.
Old 02-20-2011, 09:20 AM
Is there any type of video or pics I can view to see that setup? That's pretty much the only way I seen on how 2 bypass that security / car not starting issue..
Old 02-20-2011, 09:21 AM
77ihwheeler's Avatar
I did the resistor trick I while back in my car the stuff cost me less then $20 it was simple and I haven't had a problem with it at all
Old 02-20-2011, 09:23 AM
What's this about? I've never heard of this 1. Please EXPLAINE or is there another thread that explains more?
Old 02-20-2011, 09:43 AM
Puck's Avatar
Resistor does the same thing as the "chip" (which is just a pellet with a known resistance), and costs literally cents to do.
Worked flawlessly on my car years ago and has not given me a problem since. Hardly a waste of time it it works, was free, and was easy to do.
Old 02-20-2011, 09:46 AM
This website will help you:
http://www.shbox.com/1/pass_key.html
This is the bypass box that goes into the PCM:
http://cgi.ebay.com/ebaymotors/GM-VA...Q5fAccessories
Try the resistor mod trick first since it is easy and cheap but this is a true "bypass".
You could also send your PCM into madtuner or pcmforless and have them turn VATS off.
I have been using the 50htz box for a complete year, my car has started every single time.
Old 02-20-2011, 09:48 AM
It works the same except if the BCM is the problem like my case. I took the BCM out of the equation with my car by bypassing it completely.
Old 02-20-2011, 09:50 AM
shbox's Avatar
The 50 hz signal bypass is only half of the VATS. The most common problem is the key pellet. You have to bypass both to truly bypass the whole system.
Quick Reply: Security light comes on an tha car won't even try to turn over..
