fueling questions
fueling questions
im going with SVO redtops 30# most likely, mods in sig. will i need to upgrade stock pressure reg. or fuel pump. or will stock be fine. and yes im getting it tuned. Thanks Levi ...... anyone have some 30# injectors for sale?
Running SVO30's on your setup will be fine and unless the stock pump is giving you problems or bleading down fast after shut off there is no need to update. The stock pump will do fine on pressure and will feed those 30's fine. I am pushing over 400 to the wheels and I'm still on my stock pump maintaining 43.5 psi all the way thru WOT. Make sure to put the injector constant at 31.68 when you tune it as SVO's are rated for a lower PSI on ford motors.
