94 t/a gt trans. perfomance button pcm question
i have a 94 trans am gt with the transmission performance button im putting back together and the car didnt come with the stock pcm. so im wondering if i use a pcm out of another 94 lt1 car will the trans. performance buttom work ? is it programmed in the pcm ? so if i get a pcm without this option will the trans. perf. button work??
thanks
thanks
Just have it flashed with a 94 Program same rear gears and tranny, not all years had performance mode.
Some programs I have looked at have the feild in the program but the graph is identical to the in Drive position graph.
GT just meant it is basically a fully loaded trans am with rear spoiler, lower gears (automatic), leather, etc.
performance shift mode just means it shifts a little higher and a little firmer IIRC. I doubt my tables are any different than the non-performance shift mode now anyways
from what i heard from previous owner supposively this trans am gt i got is fast for being a stock car.
im hoping its a factory freak and is in mid 13's stock
My 97 had the performance shift tables in the pcm. Just didnt have the button. We set it so its running on it all the time now. its a slight difference in the shifts. a tiny bit faster shifts and firmer but not much. felt a little cleaner.
mid 13's stock isnt gonna happen with a stock auto LT1.
ya it will be hard with a a4 to run that time bone stock . i got a muffler and cold air intake for the car so car isnt going to be bone stock when ill take it to the track. hopefully its close to mid 13s with just those 2 bolt ons and drag radials
From what I've read the 94 GT package includes:
155mph speedo (not the 120 found in the '94 non-GT models)
Z rated tires
No top speed limiter
High Rise Spoiler
All the options leather, t tops, 3.23 gears, performance button in A4's
Never heard of a TA GT without the highrise spoiler...odd
Z rated tires
High Rise Spoiler
Z rated tires
High Rise Spoiler
Z rated tires
High Rise Spoiler
