Canton Sheetmetal Aluminum Valve Covers
Old 03-05-2011, 07:36 AM
2NASSTY's Avatar
Default Canton Sheetmetal Aluminum Valve Covers
I hear that Canton fixed the leaking problem with these valve covers. Has anyone installed a set in the last year? If so, have you had any leaking issues? Also, is there a good place to get the latest design that has this fix.
Thanks
Old 03-05-2011, 09:21 AM
bigdawg70's Avatar
No answer but nice ride
Old 03-05-2011, 10:58 PM
2NASSTY's Avatar
Thanks Man
Old 03-05-2011, 11:28 PM
Gojira94's Avatar
I bought a pair last December. They say they fab them up on a set of heads for correct fit. Iinstalled them using new OE GM gaskets. To install them straight, I used a touch of spray adhesive to affix them to the covers and installed them that way and torqued to spec (100 in. lbs.). No leaks.
