oil pump to pan clearance
Old 03-09-2011, 12:01 AM
jester1614's Avatar
Default oil pump to pan clearance
does anyone know what the proper clearance is? and are there any easy ways/shortcuts to check clearance
Old 03-09-2011, 12:05 AM
MattSapp95_T/A's Avatar
Are you talking about the pick up? IF SO...... I would always put my pick up on the pump with it hanging really low past where the oil pan would be...then I would set the pan on so it pushes the pickup back up..carefully remove the pan and push the pickup 1/4 closer to the motor to give a little clearance.....Mark it and stick a tack weld on it....
Does that make sense???
Old 03-09-2011, 12:09 AM
jester1614's Avatar
yeah the pickup sorry, so you say about 1/4 inch clearance is sufficient. and it will be tac welded
Old 03-09-2011, 01:16 AM
the_merv's Avatar
I wouldnt go more than a 1/4".
Old 03-09-2011, 02:04 AM
jester1614's Avatar
ok good to know, and so you guys know its a melling m155 (standard volume standard pressure) with a gm "white" pressure relief spring
Old 03-12-2011, 01:17 AM
That is the only pump I would run... I never did use the white spring though and my motor always had great oil pressure..
Matt
Old 03-12-2011, 01:46 AM
jester1614's Avatar
i figured for 5-6 bucks, cant really beat it (the spring)
Old 03-12-2011, 01:48 AM
jester1614's Avatar
matt my car has the same theme as yours as well, there is a pic in this thread
https://ls1tech.com/forums/suspensio...springs-2.html
Quick Reply: oil pump to pan clearance
