lt1 cam swap??
Old 03-16-2011, 02:27 AM
slim69's Avatar
Default lt1 cam swap??
alright ive done pretty much all the bolt ons and im thinking of doing a cam swap i got a 96 firebird m6 the motor is completly bone stock ive put long tube headers, ory pipe, flowmaster cat back,cai,255 in tank pump, holley adjustable regulator,160 thermostate,electric waterpump,underdrive pulley,4.10 gears,full suspension,and soloman did the tune on it my question is what would be a good cam for it i want a real choppy idle but im not gonna port or change the heads im building another motor down the road when funds get a lil better so i just wanna have a lil fun with the motor thats in it right now and im getting tired of the stock idle ive been looking at the cc306 and like the sound and hp numbers guys have been getting any suggestions
Old 03-16-2011, 03:26 AM
riceburnerZ28's Avatar
Pick a cam smaller than the cc306 or go custom. LE or AI can grind you a custom cam better suited for your setup. Use the search funtion...there's tons of threads here with all the info you need.
Old 03-16-2011, 08:05 AM
96TransAmboosted's Avatar
306 and stock heads is a waste of cam Get the 503 and you will benifit more with stock heads.
http://www.youtube.com/watch?v=_hhcBfsfWlg
It sounds pretty good to me.
Old 03-16-2011, 01:41 PM
slim69's Avatar
yea that cc503 sounds good to im going to get the le stuff for my new motor. whats the specs on the cc503 the only reason i was considering the cc306 was i was going through you tube and found a car with the same setup im talking about pull 366rwhp with it
Old 03-16-2011, 01:51 PM
slim69's Avatar
i did the lt4 hotcam in a buddies car and its a decent cam just not what im looking for
Old 03-16-2011, 01:57 PM
fatlt1's Avatar
THE COMP 306 IS AN ISSUE ALL THE TIME ON HERE.... people love it or hate it..and people who hate it never ran it and go by what everyone else writes on these forums.
i absolutely loved the cc306. i had stock block, a4 with 3600 stall, 3.73's and full exhaust and a great tune and it was awesome. it pulled all the way to the top and wanted to go some more. dont go off by comps reading of 5500-6000 or whatever they listed it at. this cam will go past that so make sure your valve train is updated as well. yes it will benifit alot better with a bigger cubed lt1 but yes you can run it and enjoy the car as well on stock block just have other parts to accomodate it. you need a stall of atleast 3200 minumum and 3.73's... its an old technology cam but still freakin works.
custom cam is the way to go always but for a stock block car with bolt ons off shelf cams are fine. i dunno what it is with people bashing the cc306, like i said thehy probably never ran it.
djjab57's Avatar
Look at the sticky sir, It helps a lot
https://ls1tech.com/forums/lt1-lt4-m...ion-guide.html
Old 03-16-2011, 02:22 PM
I have the 306 cam and it runs great for me, but if you don't have the supporting mods to work with that cam your wasting your time!
Old 03-16-2011, 04:03 PM
myltwon's Avatar
the cc306 is a good cam, but is ideal for a car with ported heads. there are other grinds out there that will get you similar peak power gains with beater average power, streetability, and less required convertor/gear for optimal performance.
the cc306 is a proven performer with ported heads and even stock heads, but it isn't the end all or best choice IMO.
Old 03-17-2011, 12:18 AM
slim69's Avatar
i have a good set of gears and clutc its a 6spd im still running the stock tb with the air foil and just wanting something that hits hard and have a little fun and pickup some decent hp i got a brand new gm847 thats going it the 383 im building for it but it wont be until next winter before that motor will be ready im just looking something that lopes pretty hard and does kill drivablityand id like to use the stock injectors and tb and intake
Old 03-17-2011, 12:42 AM
BLK95-Z's Avatar
The cc306 is a good cam, are there better ones....sure.
Ive got everything you need to do the swap bran new for sale right now.....http://ltxtech.com/forums/showthread...roller-lifters
Quick Reply: lt1 cam swap??
