What is the best Valve Spring Compressor for a rookie?
Old 03-17-2011, 08:48 PM
jaycenk's Avatar
Default What is the best Valve Spring Compressor for a rookie?
What type of valve spring compressor do you think is the easiest to not screew anything up with my rookie *** using it? Need to check these seats and clean all this freakin caked on oil up.
Old 03-17-2011, 08:50 PM
nitrous2fast's Avatar
shop! lol
Old 03-17-2011, 08:53 PM
wrd1972's Avatar
Crane dual spring compressor. One you have used it, everything else is ****.
Done.
Old 03-17-2011, 09:59 PM
jaycenk's Avatar
Done.
K gona look that up. Thanks wrd1972
Old 03-17-2011, 10:02 PM
jaycenk's Avatar
Originally Posted by nitrous2fast
shop! lol
If you knew the back story to this whole deal you would say NO SHOP!! lol J/k I have some old 305 heads and some spare LT1 heads I am gona play around on first but Gota start somewhere since my luck with shops is **** right now. Gona realy on good old me to do good enough untill I find someone I can trust.
Old 03-17-2011, 10:11 PM
Yeah that sucks when you get burned at a shop and don't want to try more; in fear of getting burned again. I luckily don't have that problem! but I do have only a few choices if something did happen.
Old 03-17-2011, 10:19 PM
Wicked94Z's Avatar
tim's tool works fine
Old 03-17-2011, 10:25 PM
gregrob's Avatar
X2 on the tims tool..
Old 03-17-2011, 10:56 PM
96TransAmboosted's Avatar
http://www.google.com/products/catal...d=0CDwQ8wIwBA#
Use a cut off wheel and cut it down some and its just like tims,larry who evers tool. And its only 9 bucks. i used this on and off the car many many times.
Old 03-18-2011, 03:38 PM
Big Bad Bud's Avatar
I used this! Worked great!
http://buy1.snapon.com/catalog/item....re&dir=catalog
Old 03-18-2011, 04:48 PM
speed_demon24's Avatar
Done.
This.
Quick Reply: What is the best Valve Spring Compressor for a rookie?
