96-97 trans harness for efi connection people
Old 03-24-2011, 12:03 AM
robsquikz28's Avatar
Default 96-97 trans harness for efi connection people
Just in case anyone is looking for the harness, I have one for ya guys.
you can easily swap this into your pcm and make it work on your 94-95 f bodies and adapt the 96-97 trans. Or if anyone just wants to convert the wiring for a tranny swap with out having to swap parts in the trans.
AUTOMATIC TRANS Harness FOR 4L60E. lt1 conversion
This is a complete harness which will pin directly into the pcm if your using shbox.com website for help. It will then fit into any 96-97 4l60e trans. This harness with fit any 94-97 f body if your using a 96-97 trans. I also have the Vss sensor wiring to allow a easy install. Perfect for a EFI connection swap
