Tunning for LT1..?
Old 03-24-2011, 05:13 PM
r0llz1104's Avatar
Default Tunning for LT1..?
Im currently filling out an application from PCMforless.com to tune my 1993 Camaro z28 w/LT1.
Seems that i have gotten stuck,
My Fuel System is stock including throttle body. Now what i want to know is if its a throttle body injection?
Old 03-24-2011, 05:24 PM
95chevyz28's Avatar
No it's not
Old 03-24-2011, 06:00 PM
r0llz1104's Avatar
Engine:
Intake Manifold : (Ported LT1)
Camshaft : (hydraulic roller lt1 270 camshaft)
Duration @ .050 .218 degrees , .224 degrees
Lift : .495 lift, .502 lift
LSA 110
Should i remove the EGR?
Old 03-24-2011, 06:19 PM
95chevyz28's Avatar
You can. You will need block off plates installed on the intake manifold.
Old 03-24-2011, 06:45 PM
r0llz1104's Avatar
Will this affect in some sort?
Old 03-24-2011, 06:54 PM
gregrob's Avatar
Are you ******* high?
Old 03-24-2011, 06:59 PM
r0llz1104's Avatar
hey greg, im new to this bro.
just asking for some advise...but, thanx for ur comment.
Old 03-24-2011, 07:13 PM
spikester7878's Avatar
i would i did on my 383 its just less **** to worry about going wrong but then again it also depends if you have to worry about emissions.i dont have to being from fl
Old 03-24-2011, 07:15 PM
r0llz1104's Avatar
hey thanx guys for the heads up,
appreciate it
Old 03-24-2011, 07:16 PM
food nd cars's Avatar
If you don't have to deal with passing smog you can go ahead and remove it, it will remove unnecessary clutter in the engine compartment. Other than that it won't affect anything as long as you have it tuned out.
Old 03-24-2011, 07:17 PM
95chevyz28's Avatar
Plus removing it unclutters the engine a little bit.
Old 03-24-2011, 07:34 PM
96TransAmboosted's Avatar
That is just great..........
Old 03-24-2011, 07:57 PM
boostedlt1's Avatar
i dont think he was trying to be a dick. your sentence construction could just use some work haha
but to answer your quesiton, no tear that **** off!!!
Old 03-24-2011, 09:31 PM
r0llz1104's Avatar
Lol, sorry greg..
Old 03-25-2011, 01:44 AM
jaycenk's Avatar
lmfao SPRAY IT!!!!
Quick Reply: Tunning for LT1..?
