LT1 to Carb
Old 03-28-2011, 07:13 PM
96z28dude's Avatar
Angry LT1 to Carb
Im putting a carb on my LT1 and was wondering if I could use the MSD 83811 distributor even though its carb'd. I will have the distributor hooked up to a MSD ignition box and there is a screw on the distributor where I can adjust the timing. So it should work right? Im still going to have the ECU hooked up to power my windows,gauges,etc.
MSD 83811 - http://www.msdignition.com/product.aspx?id=5379
Old 03-29-2011, 10:44 AM
93M6Formula's Avatar
The 20th century called, they want their technology back...
Old 03-29-2011, 12:57 PM
Ken95Z28's Avatar
No I don't see how that will work.
I would look into a normal distributor, one that goes into the back of the intake.
If this is a street driven car look for a mechanical advance distributor, race setup look for crank trigger setup.
Old 03-29-2011, 04:40 PM
Big bird55's Avatar
i agree with ken. i think you night have to cut a little on the bottom of your cowl though to fit it. i dunno though i am doing the same thing
Old 03-29-2011, 10:49 PM
z28racerlt1's Avatar
If you do a crank trigger the dist. Are very short. It will fit under the stock cowl. It probably won't come out without pulling the motor. I cut mine aoat back to the firewall. I can take the dist out without any problem.
Just my .02
Old 03-30-2011, 09:13 AM
Ken95Z28's Avatar
The crab style distributor will come out without pulling the motor.
I'm using a crank trigger setup on mine. Had to pull it one time with the motor in the car.
-- Update I don't think it will clear, I cut my cowl as well.
Old 03-30-2011, 04:12 PM
Big bird55's Avatar
im gonna try to use oen of the spare hei ones i got. not to steal his thread the guys that switched did yall manage to use your stock gauge cluster?
Old 03-30-2011, 08:31 PM
Ken95Z28's Avatar
Nope, car is used for race setup only.
Old 03-31-2011, 06:06 PM
Big bird55's Avatar
ok i can make a gauge cluster but how will i be able to have my six speed electronics work??
Quick Reply: LT1 to Carb
