factory pcm limitations
Old 03-29-2011, 05:25 PM
ElkySS's Avatar
Default factory pcm limitations
someone school me on lt1 pcms. whats the rev limit? any drivability limitations? are some years better than others? i wanna know everything i can about it so tell me what u know.
Old 03-29-2011, 05:27 PM
katz_2003's Avatar
I know you can only turn them 7200RPM
Old 03-29-2011, 05:44 PM
nitrous2fast's Avatar
the actual rpm limit for the pcm is 7000 for tuning. some can get away with running over that by 200 rpms. 96-97 pcms are obdII, 93 is speed density, 95 is a obdI pcm with a obdII connector.
Old 03-29-2011, 06:26 PM
idformula's Avatar
The 93's are also the only ones to use an eprom chip, in the fbody, 92-93 vettes, 94+ uses flash memory.
Quick Reply: factory pcm limitations
