cleaning oil off T56
Old 03-30-2011, 05:11 PM
GR33N GoblinM6's Avatar
Default cleaning oil off T56
finally got my TPI engine pulled, i had put a T56 from an LT1 behind it..
pulled both together last night in prep for the LT1 engine to go in, looks like my TPI engine had nice oil leak and my T56 is caked with 1/8" of oily dirt.
been using an engine degreaser by "Gunk".. its ok.. but is there anything else you guys use thats better?
i also have oil all inside the bellhousing, which i took off and will just pressure wash that... but i didnt want to take the pressure washer to the T56 in fear of getting water inside it. luckily no oil was on the clutch or plate or bearing, just the fork.
Old 03-30-2011, 05:14 PM
93BlackZ28's Avatar
Brake clean
Old 03-30-2011, 05:23 PM
Village Troll
SS RRR's Avatar
Mineral Spirits and a brush.
Old 03-30-2011, 05:28 PM
awesome...
i should take a picture of this utter filth... ive gone through 2 rolls of shop towles already.. been using a screw driver to scrape this crud off.. i probably have a pound of dirt off already.
Old 03-30-2011, 05:50 PM
jester1614's Avatar
diesel works well also, and you can go to your local gas station and get a whole gallon for 4.50 lol (or whatever the local diesel price is)
Old 03-31-2011, 02:30 AM
v7guy's Avatar
I always just took them to a car wash, pressure sprayed it then changed out the fluid to make sure. Never had a problem and very clean
Old 03-31-2011, 04:08 AM
Turnin20s's Avatar
kerosen works really well too. I'm probably going to pressure wash mine then change out the fluid, it needs to be changed anyway
Old 03-31-2011, 05:19 AM
idformula's Avatar
Dollar store oven cleaner, screw 5-6 dollar can degreaser
Old 03-31-2011, 06:52 AM
shbox's Avatar
A parts brush and some powdered laundry detergent made into a paste is what I have used in the past to clean really filthy parts. It may take several applications, depending on how dirty. Using the detergent leaves very little to have to clean up. I use Simple Green a lot, too. You have more to clean up when you use petroleum solvents.
Old 03-31-2011, 10:05 AM
the_merv's Avatar
I pressure washed mine with a Steam Washer when I first got it..used some degeasing Acid on it then pressure washed it off..**** was spotless..lol..
Quick Reply: cleaning oil off T56
