charging problem
Old 03-31-2011, 11:21 AM
95formulalt1350's Avatar
Default charging problem
ok i got a 95 formula when i start it up the atlternator gauge stay roughly around normal [sometimes a lil lower] but when i rev it up or get on it the alternator gauge stay on 17 volts until i come till a stop. i had my alternator tested n it is fine n i got a new battery.so if anyone can help with this problem ?
Old 03-31-2011, 11:32 AM
95 mystic ls's Avatar
Check you belt for slippage and or the tensioner for letting it slip.
Old 03-31-2011, 11:40 AM
ok will that cause the problem? and im sure its needs replace i bought the car for 2 grand with 175000 but it runs pretty good so i just want to fix for now till i build a motor
