Forced induction LT1
Okay, so Ive been looking around at all of the supercharger/possibly turbo options. I am not too bright when it comes to this type of thing, but basically I want a decent power gain and a bad-*** whine. My dad is going to teach me how to install . Suggestions? Experience? Supporting mods needed?
so you want the sound more than the power? makes absolutely no sense. how bout i sell you a cd with a procharger sound and you give me 5500 bucks?
in all seriousness people are going to argue whether a s/c is better than a turbo. personally i like turbo systems more.
but there needs to be more info than just " i want a bad *** whine" turbos whistle btw.
you need to have a power or et goal, and is your car an auto or 6 speed, you will need either a clutch or a built auto. fuel system and all the gauges. its not cheap going fi.
if your father knows his ****, just follow his advice.
I never said anything like that. By saying what I said, I meant that I want something that has a decent power gain and isn't too extreme. I heard that there are superchargers that make no sound?
i am also going through a rebuild and sent my motor off but in the meanwhile i bought a nitrous kit then changed my mind about a week ago and bought a t3 t4 turbo kit on ebay for less than a thousand and sent just the turbo back to the company and upgraded it with a 98mm i am keeping my nitrous hooked to spool my turbo so the power will be their all the time like a sc when i want to show it but not hooked up yet so couldnt tell ya about the sound an really dont care i personally like quietness so i can really suprise some little puss pony that rolls up and wants some
If you want a decent power gain, I suggest a good H/C setup. Much cheaper, been done a ton of times, and it will get you some very solid gains.
IMO, a FI setup like anything else, needs the the proper assortment of parts to work effectively and also be reliable. It really all depends on what you are looking to do. Building a 450rwhp supercharged car will be significantly different to a 650rwhp car.
First question....what is your parts budget?
If you really want to do forced induction, check out this site.
http://www.corneltechweb.com/superchargerweb.htm
This guy has done some nice work, and love the video of the car. Can be done, but is alot of work, and you better know what you are doing, or your engine will be toast pretty quickly.
hth
andy schuck
hth
andy schuck
FWIW , lawhead .. I have experience with a eBay turbo kit.. It was solid, all v-band connections, stainless steel with geat welds , I used the turbo it came with, upgraded my fuel system, put in ARP rod bolts , built trans, stock rear with 2.73 gears made 525hp @ 10psi... NO complains with the kit.. NOT a Fail..
Boost is a LOT easier on the motor than nitrous!
8lbs with a T3/T4 turbo kit would be easy to drive, won't need a high stall, or steep gears. Tuning is the only real main concern. but thats not too bad. oh and a tubular K would help with the install.
My brother did the mail order tune. Popped the rev limiter twice in one run, cracked two pistons. He had an intercooler. Which ever way you go make sure you get a good tuner.
