new IAC path for people with monoblade or other aftermarket TB's
i just got started on this today. as you can see in the photo, i have too swap to a 1/4 inch to -4 90, then to a straight -4 push lock loop the hose back to the other 90 degree then back into the intake. i have sealed the hole in the intake with silicon and will also be filling the inside hole on the monoblade. this should allow the IAC to still function correctly and use filtered air, if your car is still using a maf. my PCV was disconnected anyway due to a exhaust evac system.
i did this due to the fact i was sick of trying to tune the idle. it kept fouling the back 4 plugs and i got tired of pulling fuel on those 4 injectors and checking plugs. since the motors out right now it made since to resolve this small issue.
2nd issue
i got bored and made the hour long round trip drive to get the 90 degree fitting. then i had to deal with the new clearance issue. . since i am waiting on the straight push lock hose end, i ground off the nipple on the 90 to get it to fit. i will have to see if the threads will seal it air tight without the flare inside.
Here are some pics of my TB mod:
i also have the asm monoblade. if you look at how the factory iac is designed you can see a monoblade will not allow the factory system to work. i also had my car to idle decent but it would still foul the back 4 plugs.
BBK, Trickflows, Summits and many others deposit the idle air right into the plenum and that makes the idle BLM's go to total ****. We have to mod our TB's to force idle air into the idle air circuit like the stock TB does. Total BS but it really helps the idle BLMs. Before I had awful splits. Now with the mod, I have 128/128 95% of the time.
Does the vacuum port below the TB also tie into that same passage?
I'm just trying to understand this because I never had a reason to do it. I don't do my own tuning so maybe my BLM's are wack and I don't know. It's been a while since I've see the stock setup. The stock IAC directs air into that passage between the throttle blades right? And that passage has it's own tunnel system to each port?
I got ya. My motor is out too so I may have to try this.
One thing my car does suffer is cold start idle. Well it idles fine but you need to let it warm up for 5 minutes before you try to drive it otherwise it dies when you let off the throttle too quick. I wonder if this mod could help fix this..
that's a issue mine had as well. do you have a way to monitor your iac, once you get it back in? as i tried to make adjustments to mine it would be a 10th of a turn on the throttle blade and the iac would go from max closed (130 i think, been awhile) and go back to max open (0 i think, that might be backwards)
I have Tuner CATS and a few other data logging programs. I don't do my tuning except small things. My IAC is fully open at idle last time I datalogged it.
lol you can tell its been a year since i looked at my data logs. after neck surgery, a cold winter and a new wife, i can finally get back to the car. maybe i can finish it before king tournament season starts in june.
I thought I would ask here since it's on topic. I was messing around with my intake manifold and pulled out the bottom plugs. The air passage hole for #2 cylinder is smaller than all the rest. Does anyone else's look like this or did they not drill mine large enough at the factory?
I was also wondering if it would help to drill all the passages a little larger for big cube motors. I know the IAC can only allow a certain amount of air through. For my IAC to be effective, it shouldn't have to be fully open at idle to feed the motor.
I would just find the bit that barely fits in the largest hole, and clean them all out with that.
