1995 z28 Injector size for my fuel pump 255lph
Old 04-05-2011, 05:32 PM
95_Z-28_runner's Avatar
Default 1995 z28 Injector size for my fuel pump 255lph
i was wondering if you needed to run a bigger injector with the grandalli 255LPH fuel pump. beacuse my car boggs under an RPM load and does not have the same throttle responce. and i have the stock injectors in it. and it has a 1996 LT1 from a Corvette. does anyone know about having this issue?
Old 04-05-2011, 05:43 PM
boostedlt1's Avatar
stock injectors will be fine. why are you putting in a 255 pump? you don't need that either
Old 04-05-2011, 05:57 PM
i just put that in there beacuse it was cheaper then stock when i got it. i wonder if i need to replace the fuel pressure regulator?
Old 04-05-2011, 07:25 PM
RamAir95TA's Avatar
No, nothing needs to be changed, as long as everything else is in good shape.
Old 04-06-2011, 11:57 AM
i just dont know y it boggs under a load i did a complete tune up with wires,cap,rotor,E3 plugs,fuel filter,fuel pump, thats y i cant figure that out. then after you put ur foot in the car it smooths out. the vette motor only has 95k miles. it has slp headers magnaflow exaust, jet MAP sensor and Moroso intake. the bogging under a load its very iritating lol. t
Old 04-06-2011, 12:00 PM
RamAir95TA's Avatar
Your first mistake is wasting money on those horse **** E3 plugs!
I would check your fuel pressure first and foremost, whether you have a new pump or not.
Old 04-06-2011, 12:04 PM
ac delco i know lol ive used E3 on my other LT1 and have not had a problem. do u might think its a fuel pressure regulator beacuse when i turn the car off it wont start for .15sec.
Old 04-06-2011, 12:05 PM
96lt1m6's Avatar
Too many times we have seen people throw parts at their car without properly diagnosing the actual problem. This generally eliminates the aggravation!
Old 04-06-2011, 12:15 PM
well i dont throw parts at my cars i do full services on anything i buy. Im thinking the Fuel Pressure Regulator is the Problem. i thank everyone for there posts i like to always get different sugestions.
Old 04-06-2011, 12:40 PM
defaultexistence's Avatar
Just do a pressure test... And that will tell u if the fuel system is working properly or not... What did u gap those over rated plugs at? And describe "bogging" because a stock lt1 motor under load isnt a power monster to begin with ... Are you comparing it to something? Also lot of people know their **** here so be open minded and listen when u ask questions not argumentative FTMFW
Old 04-06-2011, 12:42 PM
BTW, no u don't change to bigger injectors simply because u put in a stronger pump... And if u do it'll run shittier
Old 04-06-2011, 01:26 PM
Wat spark plug would ya say is the best ac delco? And i think Ur rite it's probable how the lt1 is under a load.
Old 04-06-2011, 01:30 PM
95chevyz28's Avatar
Ngk tr55
Old 04-06-2011, 01:34 PM
^^^^or even autolite's gapped properly or a lil under,not saying their best.. But u would never know a difference... Only ur pocket book would..
Quick Reply: 1995 z28 Injector size for my fuel pump 255lph
