New LT1 cam??
Old 04-06-2011, 09:09 PM
CamaroOfMiami's Avatar
Default New LT1 cam??
i have a 94 LT1 Z28 and im thinking about buying and putting in the comp cams 290HR-12 cam & roller lifters or as some people refer it as the cc306 idk why. but if i put that cam and solid roller lifters would i need anything else for the engine to be good for street daily driving? like can i use stock heads stock everything else? just different cam & lifters?? i dont know a lot about valvetrain. so please specify..
Thanks
Old 04-06-2011, 10:23 PM
Low N Slow's Avatar
https://ls1tech.com/forums/lt1-lt4-m...ion-guide.html
If you use solid lifters with this cam you will need to buy some special hydraulic push rods.
Old 04-07-2011, 10:17 AM
So is it impossible to run the cc306 with stock heads and 4speed auto??
Old 04-07-2011, 11:18 AM
boosted LT1's Avatar
I suggest you read a few threads on the cam...will it work in an auto sure will you like it without a larger stall? NO
I recommend you evaluate what you are trying to do and determine all associated parts and mods. Large cam without associated mods is far from optimal.
Good luck
Quick Reply: New LT1 cam??
