LTx Street Stock....we need YOU to register!!!
Anyone remember this quote from Kyle?
There are currently 6 registered....we only need 2 more to register before may 1st!! Come on guys lets make it happen!!!
Due to time constraints, we will not have enough time for all 8 classes even though we got extra hour added this year. For those considering running this class, it is extremely important that we have at least 8 pre-registered racers for this class before May 1st. Otherwise, we will have to revert to the 2010 classes.
Class Info : http://www.ltxshootout.com/classes/
In a nutshell: this class is for bolt-on street cars. 3350lbs minimum (3200 for L99, 3450 for LT4)
No skinnies (4.5in minimum), no lexan, no tbrake, no tubbing, no strokers, no H/C cars no race brakes.
Must have opti, alt, interior, 2 seats, stock(-style) internals, factory trans .... etc...
Colin is correct. We've got a little less than a month to get 2 more cars registered for Street Stock. Surely with all the hype that got stirred up about this class there's more than 6 people who want to run this class...
Surely there is a lighter-weight bolt-on car with a huge stall wanting to represent
I figured this would be a great class for special-edition cars that don't want to modify their cars heavily.
In a nutshell: this class is for bolt-on street cars. 3200lbs minimum
No skinnies, no lexan, no tbrake, no tubbing, no strokers, no H/C cars no race brakes.
Must have opti, alt, interior, 2 seats, stock(-style) internals, stock trans .... etc...
Great new class please help support!
I guess they really are all scared of me and my hooptinator. Who could blame them? I am a sure win. I just should have waited until there were 8 victims registered to register myself and crush all their hopes. Sorry guys, my bad.
Remind you all, it's not a bolt on beginners class. It's a bolt on records class. The rules were made for a select few so you'll have a few running it. Most cars, maybe all are not even street worthy. Hardly a street class. The light weight, tubular k member, no heat or air etc. Hardly street, but good luck. The true street may have brought 30-40 cars.
You won't need a gutted track only tin can to be competitive and have fun. Sure, if you are going for the W then compromises have to be made, but it is not hard to get a car into the mid 12s and still be a 100% daily driver. Quick enough to have fun for sure.
I think the rules are very fair, and if I had a stock motor lying around then I would run in it - its a hell of a lot cheaper then my stroker, would be easy to finish on time, and I wouldn't give two ***** if it broke! At the rate I'm going I won't be ready for the shootout - the motor is done but I still need a stall, transmission, and a computer/harness. Not cheap, and i have a lot of priorities and a lot less disposable income then when I started. I could run the car as-is with a weaker bolt-on engine and be worry free - how many people drag race without being nervous about blowing up a $3,000 shortblock or grenading a 2k rear end?
It sounds like a blast to me!
Any DOT legal rear tire allowed that fits within the stock un-altered wheel opening. May not stick out past the fender. No slicks.
Front Suspension: Direct replacement aftermarket A-arms permitted. Stock type drag shocks allowed. Must be in stock location. Sway bar may be removed.
Rear Suspension: RearBolt-in aftermarket components allowed. Stock style replacement sway bar allowed. No wheelie bars or coil over shocks allowed. Aftermarket torque arms permitted. Front mount of torque arm may be relocated. NHRA legal bolt-in traction bars allowed (Pete-Z, etc.).
Chassis: Tubular bolt-in replacement K-member permitted. Sub frame connectors permitted. Rollbars are optional.
Steering: OEM steering required. Power steering pump may be removed or bypassed.
I think "most" is a big exaggeration. The field won't be spread by very much and a lot of it will come down to driver skill and reaction time. A couple 10ths can easily be made up at the tree - these are low powered cars, and even with a fairly aggressive bolt-on setup you won't be doing much back half hunting if you get pulled hard off the line.
Well that sucks, I have QA1 rear coilovers on my car. So, that takes me out of this class. Too bad, I really wanted to run my car in this class.
Bottom line is if u have a 12 sec bolt on car you will go rounds and have a chance to win.everyone is worried their car wont have enough to compete. But like they say racing is racing and you gotta be in it to win it!
Edit: i honestly could even see some low 13 sec cars doing some damage and going rounds. Dont be discouraged come out and race. Where else will you be able to race a true heads up class and be competitive? This is a one of a kind oppurtunity to race heads up on a budget. Come out race and enjoy the event and the weekend. Thats my plan neways.
I would definitely run this class, but rules are making it hard for a true street car like mine to run. My car probably weighs in the 3600 +/- range and all of the factory options are intact and working. The motor has every imaginable bolt on along with every imaginable suspension piece, but somehow because I have coil-overs on the rear my car is not eligible. I think my car is the epitome of a true street with working A/C, T-tops, but why I can't have a coil over on my 12 bolt rear end is beyond me. I don't know how that is unfair when I'm dealing with a huge amount of weight (3600 +/-). I already know my car would be competitive from my old ET's (12.61 @ 109) that was with stock suspension and a few less bolt-ons. My car should be a 12.30/12.40 car @ 110 + with the suspension and few extra bolt-ons since that old ET.
