ATI balancer hub ?
Old 04-07-2011, 05:41 PM
SPEEDYTRANSAM1996's Avatar
Default ATI balancer hub ?
anyone running this on a 96 lt1 car using a single roller with ckp reluctor still. Does this interfere with anything at all?
http://www.summitracing.com/parts/AT...n/?prefilter=0
Old 04-07-2011, 05:56 PM
BALLSS's Avatar
I run the ATI full hub & balancer on 96, stock timing chain, no problem
Old 04-07-2011, 09:44 PM
James Montigny's Avatar
No issues here either.
Just don't use the spacer they provide, it's for cars that don't have reluctor rings.
Old 04-07-2011, 10:52 PM
u mean that little spacer/washer?
Ya I wont be using that
Old 04-07-2011, 11:23 PM
355z28's Avatar
Did you find your car, or new one your working on?
Old 04-08-2011, 08:43 AM
The ATI hub ships with a spacer that is exactly the same thickness as the reluctor ring.
Early LT1s don't have a reluctor ring, so the spacer is needed to keep the belt in line.
If you install that spacer on a car that DOES have a reluctor ring, the ring ends up smashed against the timing cover and out of range of the CPS.
(LFMF )
Spacer - http://i38.photobucket.com/albums/e1...n/IMG_9157.jpg
Damaged timing cover - http://i38.photobucket.com/albums/e1...n/IMG_9153.jpg
Old 04-08-2011, 12:39 PM
robsquikz28's Avatar
(LFMF )
Damn, James that sux and thanks for the info.
Quick Reply: ATI balancer hub ?
