how do i know if my motor sezied up?
well today i drained out the oil from my car that had been sittin for like 4 months and and my dumbass drove it for the first time about a week agoo ..so then after that day i drove it .. it didnt want to start no more.. it sounded like a starter alternator issue cause all i would here is a click click click sound...so then today i changed out the oil cause it looked odd in a watery sludgy type situation....so i assumed its from the condensation of the climate change... and now im afraid apart from the startin issue that it might have fucked up the block
try pulling the starter off and use a screw driver and pry the flywheel tooth by tooth clockwise and if it turns easy your motor will at least last a little longer depending on if you did have water in your oil
