wideband
I think he means his WOT switch (as in for an N20 setup).
You might have better luck posting in the nitrous forum, the WOT switch is a pretty common install.
My understanding is that it is a relay looking for a minimum voltage from the TPS as a trigger.
You talking about the wire on the throttle position sensor that tells your PCM when it's at wot? Does the Gage or whatever you're using have a program that allows you to calibrate to the voltage?
I understand what you're saying. Your wideband has a memory that will display what it was reading while at wot so you can see without having to stare while driving. It will also turn n a warning light if you hit a dangerous afr.
what type of sensor system is it??? autometer, innovate????
i would assume the WB02 is just looking for a voltage from the TPS that is above 4.5 or so.........if thats ur case theres a three wire plug going into the TPS......IIRC its the white wire....check shbox.com he should have the schematic listed on there
its a auto meter wide band 4378 thanks http://cgi.ebay.com/ebaymotors/AUTOM...item2eb2c2997b
